Help me with my W202
Discussion in 'Electronics' started by AK84, Oct 30, 2008.
  1. AK84
    AK84 New Member
    26
    Oct 24, 2008
    Hi guys!
    I'm new here. I bought my first car yesterday [​IMG] A 1996 Mercedes C180 Elegance. I'm loving it! But I have a few questions. I hope you can help me.
    1. There is this button I've marked with a red circle, what's its function? It's not listed in the manual.
    2.The other question is regarding the blower fans/climate control. When I put the vents to 1,2,3 or 4 or even 5 then they blow like if I put them on full. I have to push the fan controler a bit inside for the fan to blow lower (or I have to play a bit with it pushing it and so on). [​IMG] So what can be the problem?
    Thanks in advance!
    P.S. Sorry for my english [​IMG]
  2. 230K
    230K Hardcore MB Enthusiast
    2,190
    Jun 1, 2003
    Belfast
    Car:
    09 E320 cdi Sport Estate, 98 E300TD Estate, 99 SL 500
    Hi
    Did you not get a manual with the car???
    Anyway, the button disables either the internal motion sensor or the tilt switch depending on whether you push it up or down before locking the car.
    Useful if car is being towed away or on a ferry and if for example you left a dog in the car or a window ajar then alarm will not go off. It resets after yiou open the car with the fob.
    Welcome to the club by the way.
    230k
  3. Spinal
    Spinal Hardcore MB Enthusiast
    4,793
    Sep 14, 2004
    Uxbridge
    Car:
    Smart, S320 and C180 with 3-pointed stars amongst others
    Welcome!
    As 230k says, the button you've circled enables/disables the motion sensor for the alarm. Towing the car (or for that matter, putting it on a truck/ferry or having it hit by another car while parked) will set off your alarm/immobiliser.
    The fan control sounds like your knob is loose or like the resistor at the back is faulty... shouldn't be too expensive to fix...
    M.
  4. recycled
    recycled Hardcore MB Enthusiast
    4,278
    Feb 26, 2007
    welcome. as above
    are you sure yours is 1996 as i do not think they had those sensors in 1996 mine is 1997 and i do not have it.
  5. NW_Merc
    NW_Merc Banned
    5,918
    Sep 3, 2005
    Over here, sometimes over there
    Car:
    1994 Mercedes C180 classic
    Could end in tears :D (sorry childish I know)
  6. 230K
    2,190
    Jun 1, 2003
    Belfast
    Car:
    Hi
    My 96 C Class Kompressor didnt have that button, maybe its a dummy, does the light flash when alarm is armed? Do you have lights in your RVM?
    230K
  7. recycled
    4,278
    Feb 26, 2007
    I also think you have a problem with your knobs. looks like someone has removed the dash and not put it back in properly or put another one there.
    see the defrost symbol by 5 is not showing as well as the head of the guy in the right defrost button or is it the way i am looking at the picture
  8. MercFanUk
    MercFanUk Hardcore MB Enthusiast
    1,258
    Sep 22, 2008
    South Yorkshire
    Car:
    It's just been covered up by aftermarket chrome rings.
    Those alarm buttons were available pre 96, but were option only, and quite rare IIRC.
  9. gurpz
    gurpz Administrator Staff Member
    3,766
    Jan 28, 2007
    London
    Car:
    Mercedes C230K Sport
    Correct, Inkyskin's pre-pre facelift had that option too and indeed very rare on those early models.
  10. OP
    OP
    AK84
    AK84 New Member
    26
    Oct 24, 2008
    Thanks guys!
    Uhm, so it's the alarm... But when I bought it they said it hadn't. Yesterday it wasn't flashing. But today I pressed it up and down. And now when I leave the car the tiny red lamp flashes. I just don't understand why the one who sold it to me said it has no alarm. How can I test if it works?
    I'll put up some pictures of the car tomorrow (from inside too). And thanks to everyone for the warm welcome!
  11. MercFanUk
    1,258
    Sep 22, 2008
    South Yorkshire
    Car:
    Lock the car with the keyfob, then unlock and open with the fixed key - it should set off. If it doesnt, get in the car, lock the central locking, then wait 30 secs, then start moving, you should set off the internal motion sensors, an viola, alarm should sound :)
    If it flashes when you lock the car, that should mean it's setting (thats what mine does too).
  12. OP
    OP
    AK84
    AK84 New Member
    26
    Oct 24, 2008
    Well, then I should try it tomorrow :)
  13. gIzzE
    gIzzE MB Club Veteran
    5,641
    Jan 20, 2004
    Norfolk, UK
    Car:
    530d Touring + ML270 Inspiration
    How do you know if the sensor is set to off??
    Reading the manual it says you should see the light come on when pressing it.
    However, there is no light on mine (2000 w210) but I have left the dog in the car and the sensor doesn't seem to go off.
    It flashes when it is locked, so the light is working, just not confirmation that it has been set.
    Does it only flash or flash differently if the sensors are disabled??
  14. OP
    OP
    AK84
    AK84 New Member
    26
    Oct 24, 2008
    That's a good question. Anyone? So if I'm correct it should flash when it's enabled. Or is it the other way?
  15. KillerHERTZ
    KillerHERTZ Administrator Staff Member
    16,921
    May 21, 2003
    Cambridge
    Car:
    CLS63 AMG
    Keep pressing until the lights stop flashing. or simply start the car
  16. gIzzE
    5,641
    Jan 20, 2004
    Norfolk, UK
    Car:
    They never start flashing though, that is the problem.
    The only time it flashes is when the car is alarmed and locked.
  17. stevesey
    stevesey Hardcore MB Enthusiast
    2,969
    Sep 3, 2007
    Bristol
    Car:
    Alfa 156 1.8TS
    Karl - it that ride height (and the sills) real in your new sig photo, or have you been photoshopping.
  18. OP
    OP
    AK84
    AK84 New Member
    26
    Oct 24, 2008
    I tried it but no alarm :( Then why is that button there if there is no alarm :confused: I don't understand.
  19. MercFanUk
    1,258
    Sep 22, 2008
    South Yorkshire
    Car:
    It's possible it has a fault - next time you get the codes read on a STAR machine, see if theres anything popping up regarding the alarm
  20. KillerHERTZ
    16,921
    May 21, 2003
    Cambridge
    Car:
    CLS63 AMG
    Sills are the same - non AMG, wheels highered by about 4 pixels
Tags:
Share This Page
