Help mercedes c220 cdi w203 face-lift
Discussion in 'Parts, Maintenance & Servicing' started by James0210, May 15, 2018.
  1. James0210
    James0210 New Member
    2
    May 15, 2018
    Belfast
    Car:
    Mercedes
    Hi folks my main drive belt burnt up and broke after investigation I see the ac pulley isn't turning freely and the plan was to use a smaller belt and bypass the ac but not enough clearance of the ac pulley to do this any ideas would be very welcome thanks
  2. alecmascot
    alecmascot Hardcore MB Enthusiast
    167
    Mar 16, 2016
    North East UK
    Car:
    C220 CDI 57 plate
    The AC pulley won't turn freely as the pump is the type that does not have a clutch; unless of course something is broken and it is very stiff ?
  3. OP
    OP
    James0210
    2
    May 15, 2018
    Belfast
    Car:
    Mercedes
    It turns a bit then very tight
  4. markjay
    markjay MB Club Veteran
    19,554
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    Can you unbolt and remove the AC pulley altogether (and use a smaller belt)?
  5. alecmascot
    167
    Mar 16, 2016
    North East UK
    Car:
    C220 CDI 57 plate
    OK. Then it is stuffed......
    As I recall the AC pulley drives the pump via a rubber isolator, maybe if that was removed the pulley would free-wheel !!!
    I think there is something on youtube about that....
    But it is all clutching at straws I think.
Share This Page
