GrahamS
Hi chaps as the title says my CLK 230 Kompresssor is leaking fuel from one of the components at the rear of the car. I am not sure what is back there but i'm assuming that there is a pump and filter amongst the pipes and tank. At the moment it only leaks during the first start of the day after that it seems to be fine, so I am guessing there must be a reservoir or something similar that pools overnight and then leaks when the system is used the next morning but then doesn't leak for the rest of the time the system is in use. Does anyone know either how this all works or whether it is a known problem with a simple fix?
Any help would be greatly appreciated
Cheers
Graham
Cheers
Graham
