Help - My SL Shrank!
jonthetourist
Glos
SL 300-24
Or at least it felt that way as I set off this morning. The headlining on the hard top has detaached and drooped a couple of inches.
Has anyone else had this / know the best solution?
Thanks in advance
Jon
Hard top on...
take it off...
joking aside, I've used the 3M spray glue before now to stick this type of thing back up Its very sticky and come with a straw such as a wd 40 can so you can get it into tight areas. I would have thought that would do the trick?
Hard top on...
take it off...
I guessed "take the roof off" would be a response :)
The plan is to fix it when the roof come off. I worry about spray glue in case I end with creases and wrinkles, so wondered if anyone had haste problem before.
Jon
