Help needed - CLK 350 - Engine light
Charlie991
London
CLK 350 Sport [W209], E240 [W210]
Hi All,
After searching for sometime, I finally purchased my CLK 350 cabriolet (2007) [VIN: WDB2094562T085026] about a week ago and having driven it for less than a week the engine management light came on saturday evening 😖 . The car has done 88.5k miles (4 mere + 2 indie stamps) and has not been driven much, only done 1900 miles from the last MOT, +8k since April-22. The MOT was recently completed prior to sale of the car and passed without any advisories. The car is well maintained and no signs of abuse.
As I was due to drive to Birmingham on Sunday, I called out the AA to see if they could diagnose; the 2 error codes which showed up were:
0276: Inlet camshaft timing control (bank 2)
Signal improbable
0060: Outlet camshaft timing control (bank 1)
Signal improbable
Since the AA cleared the engine codes the car has since been driven around 50 miles (all locally) and no light. There is no rattle from the engine, the car starts and drives fine.
As you can imagine I'm absolutely gutted for the CEL to appear less than a week after purchase, without any obvious signs (i.e. no rattle), I am at a loss as to what it may be. Possibly sensors? given the car has barely been driven over the last year or since 2022.
Has anyone had any similar issues or any advice... it would be most appreciated.
Gutted,
Charlie
It will probably be one of two things.
The cam actuators are faulty or it has a worn balance shaft. There is modified cam actuators available from MB and they are only £23 each IIRC. I would probably put a set of those on firstly and see how you get on.
If its a balance shaft issue that's certainly a few quid to sort. I have not ever seen one fail completely though....
Charlie.
Welcome to the Forum.
Was this a private purchase or from a dealer?
Hi All,
Has it only been serviced 6 times?
sorry, has had 13 services (was typing from my phone!); service schedule as follows with oil change done at each interval.
2.5k [2008] - oil changed
4.5k [2009] - oil changed
8.2k [2011] - oil changed
12k [2012] - oil changed
18k [2013] - oil changed
27k [2014] - oil changed
38k [2015] - oil changed
45k [2016] - oil changed
52k [2017] - oil changed
56k [2018] - oil changed
61k [2019] - oil changed
72k [2021] - oil changed
86k [2023] - oil changed
Hopefully both air filters have been changed as required along with the fuel filter. Has it had a gearbox service?
Air filter was last changed 56k. Fuel filter looks like it was changed 2012? (as per the service book...). No gearbox service completed.
Where in London are you so someone can recommend an MB specialist for you …just in case buddy .
Amen. And BlackC55 “knows his stuff.”
The important bit is twice in the last five years
The EML problem is almost certainly the sensors, as discussed. It’s not an expensive fix
Wayne Gates in Harrow, or Nigel at Alexander’s of Twickenham are the two obvious locals.
If you can, I’d drive the 50 miles down to PCS at Horndean, but you might think that a bit of a trek.
Thanks all for the input, greatly appreciated.
I have been driving the car since Monday, pushed it a little bit yesterday too with no light reappearing.
If it was the worst case scenario/sensors would the expectation be for the EML light to reappear relatively soon? Rather than enjoy the new ride I'm driving it with a continuous eye waiting for EML light to come up 😫
