gj77
Hi all,
I'm hoping that somewhere within this pool of knowledge, there might be an answer, or at least a clue to point towards the root of my problems.
I've got a 1996 W124 E280, with 200,000 miles on the clock. I've had it for two years and in many ways it's been great, but has had some issues (mostly wear and tear), however it has now had a problem starting for a couple of months which seems to be stumping everybody, mostly because it's intermittent and because no error codes are being recorded. Most of the time it just turns over but won't fire. The fuel system and ignition system have been tested and are working, but when this issue occurs something is stopping the fuel from making the final leg of it's journey through the injectors and therefore firing the engine into life. Occasionally, the old girl forgets that she has this problem, fires into life as soon as I turn the key and runs like a dream, until she decides to let me down again. The local mechanic I've been using is very good; he's an older guy with many years of experience and a slow and methodical nature, but he can't solve it at the moment, and until she decides to fire up again, I can't even get the car back to him.
Thanks,
Glen
- The crank shaft sensor has been changed.
- The loom has been rebuilt around 18 months back.
- The ECU was sent for repair and reconditioning 18 months ago.
Thanks,
Glen
