Help no heat! W203
C32Graham
W126 300se E34 520
Not sure if this is engine or interior tbh but bit of an issue as its -5 this morning!
Car is a 2003 C32.
I have always thought that the heating has been poor on the car but never really worried. This cold snap has proved that its barely working at all. At best all I get is luke warm air after about 30mins.
I've done the reset and it just leaves the 2 lights flashing, I have no clicking noise to suggest a broken valve and I can hear all the air moving about during the test. I understand this means that its logged a fault. When looking through the history I found a receipt that notes post water pump change:
"unable to test heating due to heating system fault - customer aware"
so sounds like its not a new thing.
Any hints or tips? Bloody typical as Im trying to sell it!!!
Chrishazle
Nr Ashford, Kent
2008 S204 C220CDI Elegance Estate Auto, 2008 R171 facelift SLK280 Auto.
On my 203 this was part of the effect of a faulty thermostat, the other effect being that the engine temperature never got above about 60 instead of getting to 80-90. Mine was a C270, wonder if you have the same (easily fixed) problem!
OP
OP
C
C32Graham
W126 300se E34 520
Sadly I think not. Engine comes up to temp fine and sits at 85-90 fine.
Good shout though!
OP
OP
C
C32Graham
W126 300se E34 520
For a bit of closure. Was at the garage yesterday. Diagnosed as either water pump or thermostat. Car had a water pump last year so booked in for a thermostat later today. Thank god, a nice cheap fix!
Rory
Cheshire, UK
C270CDi Estate (late 2004 facelift model)
If it gets up to temp OK, then odd that the heating is only like warm.
grumpyoldgit
Stourbridge
C270CDI Avantgarde SE
Suggest you get them to check that problem with reseting the heater flaps while they're doing the stat.
grumpyoldgit
Stourbridge
Did a new stat solve the problem?
