pint6x
I have no car currently and need to buy something cheap which will give good service for a few years without too much associated financial ruin!
I like the 2002-2010 CLK - probably a petrol 2.6 or 3.2 - or maybe a W211 E class - prefer 6 cylinder petrol engine but not averse to 4 cylinder, so long as it's reliable.
I have been looking at stuff on autotrader up to £3,000, probably older petrol - quite like this one:
Mercedes-Benz CLK 2.6 CLK240 Elegance 2dr
though previous MOT advisories look a bit daunting:
Advisory notice item(s)
- Offside Front Seat belt damaged but not affecting the operation of the belt (5.2.2a)
- Rear registration plate deteriorated but not likely to be misread (6.3.1d)
- headlight lenses deteriorated
- Offside Front Brake pipe slightly corroded (3.6.B.2c)
- Offside Front suspension has slight play in a lower suspension ball joint STRONGLY ADVISE REPLACEMENT (2.5.B.1a)
- Suspension arm rubber bush deteriorated but not resulting in excessive movement BOTH FRONT LOWER INNER (2.4.G.2)
- Nearside Front TYRE WORN THIN ON EDGES OF TREAD
- Offside Front TYRE WORN ON EDGES OF TREAD
- Rear coil spring corroded SPRINGS (2.4.C.1b)
- Windscreen has damage to an area less than a 40mm circle outside zone 'A' (8.3.1d
