LeighW
- Feb 8, 2006
- Location
- Leicestershire
- '06 Jaguar XJ, '00 Obsidian black CLK320 Avantgarde, '05 Mitsi Colt, '96 GMC Safari
Hi everyone, I've just joined the forum, hope someone can help me. I have a 2000 CLK320 Avantgarde which has developed a fault. Yesterday when I started it from cold, it seemed to be running slightly rough, when I pulled away it was really lethargic, and the check engine light flashed, then stayed on. The rough running went away, but the performance was flat (I'm guessing it has some sort of limp home mode?). Anyhow, the light still illuminated when I drove to work this morning, but after I stopped at a shop on the way to work, the light went out when I restarted the engine. I rang my local MB dealer (Loughborough Mercedes) and arranged for them to plug it into their diagnostics. The report shows it has misfired on all 3 cylinders on the left bank (as you look at the front of the car). The technician (very helpful chap) thinks this all points to one of the cats (probably the rear - I didn't realise it has 4!) breaking up and blocking the exhaust. He wants me to leave the car with them, they'll remove the suspected faulty cat and tip water through it to see if it's flowing ok. Apparently I'm looking at over £800+vat for the part alone, plus labour of at least 2 hours at £95+vat per hour. Ouch.
Does anyone know of a cheaper source for the parts (if it turns out the cat has failed), a decent specialist in my area - North West Leicestershire, or alternatively, would a much cheaper fix of replacing the rear pair of cats with straight pipes have an adverse affect on performance? Would the car pass it's MOT on emissions with just the front cats?
Any help at all would be gratefully received.
Leigh
Leigh
