krotov71
I can not remove the inner driveshaft joint from the passenger side!
I disconnect it from the wheel hub and take it out, the inner part of the joint still seat on the splines. The car on the stands, I got under and try to use small bar and hummer , it moved for 2mm and stuck, what should I do? its GLC43
