Smarties
- Oct 14, 2008
Hello fellow forum members. May I pick your collective brains regards a non-starting issue on my 2002 SLK230 Auto.
Long story short, With winter approaching, I disconnected the battery from the car approx. Oct last year, in the knowledge that I wouldn’t be using it over the coming months and in an effort to overcome battery drain and a flat battery when I came back to it.
Re-connected the battery, (after charging it), a few days ago. All seemed fine until I came to actually starting it: doors lock, unlock, indicators flash etc., no problem, turn key in ignition all warning lights illuminate, turn to crank engine and nothing!!
Read on a forum posting to disconnect the battery again and reconnect without trying to start it for half an hour or so…did that, no good.
Got a mobile tech out today, no MB diagnostics on board, but did have some snap on fault readers etc. He started the car by wiring the starter to the battery, fired up, albeit a bit lumpy, and ran fine.
Noticed the gearstick will not come out of park without using the manual unlock behind the gearstick, even with engine running, also the brake lights are on all the time.
After all said and done, he was of the opinion that it is an immobiliser fault, due to the length of time the car was left without power, and that it has lost all its memories/settings etc.
Any thoughts before I put a match to it, or alternatively get it recovered. 2002 car, 38000 miles! Battery was new last year as were key fob batteries. Thanks in advance.
