CLK 320 W208
Hi All,
I have recently bought a CLK 320, 87K 2002, and have a few suspension/steering problems. (although I did test drive the car, should have been more thorough and taken it on the Motor way :O( )
1) Steering damper is leaking, replacing this appears to be a quick fix is it ?
2) Steering bobbles at around 60mph and stops bobbling above 65, balancing and tyre pressure are ok, any ideas why this may be happening? An considering changing the ball joints, is that a good idea?
3) Car pulls to the left quite considerably, again any advice on what may be the cause?
Could all of the above be down to the steering damper problem…..
Any help on this matter will be much appreciated
