vtechnician
- Feb 1, 2012
- mercedes c230 w202
Refilled the air-con gas.
Jumped the A/C compressor to battery +ve and the clutch works.
Jumped the pressure switch for the refrigerant compressor-still doesn't engage the clutch.
Tested the compressor cutoff relay and the wiring - all is good.
Replaced the control unit,automatic temperature control which is behind the glove box.
Removed the operating unit,automatic temperature control which has the temperature selector wheels,EC button etc.Stripped the unit and tested all the components.All seems ok.
Any ideas as to what the fault could be?
