Cannot find that part no. on the Mercedes online epc I use.
However the grille badge part number for the W205 is listed as A0008880060. This part number is also used on the A Class.
hth
Thanks, yes can see that now. So the star on the W205 does also fit the A Class so reversing that suggests that if A0008880400 fits the A Class then it should also fit the W205. Can now see a pic proving the part no. so baffled as to why it is not showing, unless the epc am using is not up to date.A0008880060 is the 'hollow' star. I think the OP is looking for the flat shiny one - the comes on cars with Distronic (it conceals the front radar sensor).
Thank you, hope they are interchangeable, was only £25 so if it don't fit I'll just sell it on listing the part number.Cannot find that part no. on the Mercedes online epc I use.
hth
Thank youThanks, yes can see that now. So the star on the W205 does also fit the A Class so reversing that suggests that if A0008880400 fits the A Class then it should also fit the W205. Can now see a pic proving the part no. so baffled as to why it is not showing, unless the epc am using is not up to date.
