mattc
hi all
lifting up the seals on the inside of the load area shows some rust which needs attending to.
Given the thing is leaking a guess i need new seals for those rear panes. I looked on the russian site and plugged part number in and a new seal came out at £93 on the mb parts catalogue!! is that right. Am I even looking at the right item.
http://www.detali.ru/cat/oem_mb2.as...GM=717.440&CT=F&cat=44R&SID=67&SGR=045&SGN=02
I put code 1246701939 into the system; is it actually part 1246730698 I need for both sides (cannot be as its too cheap at 58p!)
Sorry for not being able to insert the image - I am crap with this sort of thing!
