Help with W211 CD Changer
adnaniqbal
Surrey
W211 E270 CDI
Hi
I have a w211 e270 cdi which has a standard satnav with a single CD. I am either able to use the satnav or play a cd so looking to install a CD changer. Can anyone tell me what I will need and can I install it myself?
Thank you very much.
npuk
London
A180 CDI Avantgarde SE (2008)
I assume you have the APS50 navigation as Comand has a seperate navigation processor in the boot so you can insert a cd in the front headunit while using navigation.
You need the 6 disc 1 slot cd changer shown on the link below and the W211 fitting kit also on the link below:
Comand Online Ltd :: Other Mercedes Retrofits :: Mercedes CD Changers Comand Online are based in Woking, Surrey and will able to fit it for you if needed.
It fits in the compartment under the headunit. Guide on how to remove stereo etc can be found at: W211 E Class
Ebay will have some second hand cd changers.
OP
OP
adnaniqbal
adnaniqbal
Surrey
W211 E270 CDI
Thank you so much. One other thing if you know, my car comes with phone prep, is it possible to have a bluetooth connectivity for the phone, and if so what will I need?
Thanks once again.
npuk
London
