jim4ewa
- Feb 20, 2017
- w205
Hi all,
Been on pre-MOT check for my 2017 C220d W205.004 at my local test centre last week and been advised that there is a squeaking noise from the auxiliary belt tensioner that will require new auxiliary belt, belt tension and belt idler. All totalling £589 with the 4 hour labour.
Had replaced all these myself on my previous W204 and decided to save the money and roll up my sleeves. After listening pinpointed the squeaking noise to the tensioner / water pump area. After entering my car reg. ordered non-OEM water pump (Dolz) and tensioner pulley from Autodoc.
Parts arrived yesterday, took the original water pump out, but discovered that there is minor differences between new and old pump. The replacement pump is missing a hole seemingly connected to a vacuum tube going behind the water pumps pulley with an opening at the gasket side. There is also tiny hole at the base of the pulley that is missing on the replacement pump (please see photos).
Has anyone replaced one like this before? Can you advise if is alright to install it. Felling like Autodoc has wrong pumps on their site. Do you think the hole does anything, bearing in mind that it stops at the gasket?
Any help would be appreciated.
