Note: This feature currently requires accessing the site using the built-in Safari browser.
But you do drive like Miss Daisy2017 C Class estate here. That rate of wear is astonishing.![]()
Or miss daisy's chauffeur..........But you do drive like Miss Daisy![]()
Good point well made!Or miss daisy's chauffeur..........
Absolutely. I’m old ya know. Very old.But you do drive like Miss Daisy![]()
Down to 2.5 across the tyres don't drive hard or harsh. Car goes to mercedes for service and MOT every year. Never find any problems with suspension.Welcome.
When you say "only lasting", do you mean that you have remaining thread depth of 3mm or less across the tyre (both sides, and centre)? And do you regularly check the tyre pressures to ensure that they are within the manufacturer's recommended range (as per the sticker inside the fuel flap)?
If the answer to both questions is "yes", then either you are using the accelerator too hard, or the rear shocks/springs have failed resulting in tyre spin.
If the answer is "no", then we'll need more info about what's actually wrong with the tyre, preferably with photos.
Changing tyres to Continental's on Wednesday 22 as that's what the tyre gge have suggested. As they don't rate Pirelli.
Fronts are coming up to 17000 and have about 4.3mm left same tyres make Pirelli.
Thanks for your response will see what the next one's do
Thanks for quick reply front have 225 on back 245 so can not swapFirstly, unless you have staggered set up, them it's recommended to rotate the wheels back to front every other service or so (depending on mileage), to ensure even wear of all 4 tyres - this way you can replace all 4 tyres in one go, which is the sensible thing to do.
Then, given the condition of the front tyres, in my opinion your issue has nothing to do with the make and model of the tyres, but with the car itself. I am willing to bet that the tyres are either slipping or dragging.
Get full-geometry suspension alignment done at a reputable place, then have the rear suspension as well as the brakes (and parking brake) checked.
I've the 4 matic estate version, came with run flat Contis from new and managed 28,000 miles from the rears.Hi have a C250 d Amg Line Saloon 2017 rear tyres are only lasting 4,000 miles. Pirelli Cint P7. Is this normal and is there a better tyre to use.
Don’t fit new tyres without having a full four wheel alignment done at a specialist with a good reputation, as the same will happen to your new tyres if the problem is with the geometry.Down to 2.5 across the tyres don't drive hard or harsh. Car goes to mercedes for service and MOT every year. Never find any problems with suspension.
