Do you know what system you have? Audio 20, Audio 50, Comand?
If the Audio options and you have the NAVI button, check to see if there is the pre-installed wiring to take the Becker unit in the glovebox. If you have this then its a case of buying one of the modules. Still not cheap and you need to avoid the fake units out there.
Use Waze on a mobile phone, it is far better than any builtin satnav and is free.
No if you mean the car display.Thank you. Can this be made to show directions though the screen
Based on the above the answer is that it does have built in satnav.
The people linked above will know what can (or can not) be done to add satnav to the car.
You are correct, sorry... should read 'does NOT have built in satnav'.I think you mean doesn't have built in satnav. If there is no NAVI button then as far as I know that means it doesn't have it.
OP If you contact Commandonline.co.uk they will need your VIN number, so have that to hand.
