Hi paul from stoke
Percy1967
Stoke on trent
C180 kompressor
Hi could do with some help on my dads c180 kompressor 07 plate petrol a few days ago it would not start turns over trys to fire but no start I have checked fuel pump and it's ok checked fuel presure at rail 50bar changed both cam sensors still no start removed plugs and tested with spark tester all ok but noticed plugs seem dry could their be a fault with the injectors or ECU? any help would be grateful thanks paul
You have fuel & spark ; do you have vacuum in inlet side , or is there a leak ?
Plugs being dry ( no smell of petrol ? ) suggests fuel isn’t being injected ?
Do you have access to a fault code reader ?
Hi thanks for reply I will get one from work tomorrow a snap on solas can read live dater with it so i can see whats happenig
Hi guys plugged code reader in today and got two codes stored p200b b6/1 cam hall sensor and p202b can message from electronic ignition system modul
Hi well just stripped covers of to check timming and it looks like its jumped noticed some teeth missing of cam gears as well will this also damage the valves and any thing else thanks paul
