computerman
- Nov 16, 2014
- S55L AMG Beast and S600L Monster!
Anyone know if it's easy to "downgrade" from factory HIDs in my W220? It's a '99 model, and has just the dipped beam as HIDs, not a bi-xenon model.
What I wanted to investigate - is it possible to retrofit some after-market headlamp assemblies, and either incorporate the factor HIDs into them, with LEDs for full beam, or else downgrade the factory HIDs to an aftermarket set?
There's loads of info out there I've perused, but can't find this combination anywhere. All the cheaper aftermarket headlights seem to specify "not compatible with vehicles with factory-fit HIDs"... is this a wiring issue, a physical size or assembly constraint, a safety concern or something else? Is it not possible to transfer the HID bulb holders to an aftermarket reflector headlamp?
These maybe:
W220 1998-2005 98-05 LED DRL R8 Projector Headlight Chrome for Mercedes Benz 99 | eBay
or if not these:
W220 99-06 CCFL ANGEL EYE Pro HEADLIGHT for MERCEDES | eBay
or maybe even these:
Mercedes S-Class W220 1998-2005 Sal - Marelli Near Left Side Headlamp Headlight | eBay
And cheapest is these:
http://www.ebay.co.uk/itm/Mercedes-...05&prg=11472&rk=1&rkt=6&sd=381039146318&rt=nc
I understand that the car has to be STARred to tell it its been upgraded to HID, so presumably the reverse applies if I rip out the factory HIDs and go aftermarket on those s well as the headlamps?
Confuzzed...
These maybe:
or if not these:
Confuzzed...
