Crazyjester900
HID XENON KITS - Are they Illegal?
cheers
cheers
As BTB500 said, you MUST fit headlamp washers AND auto levelling as well. Otherwise it will fail the MOT.
I'
So, yes, they are illegal, but it's highly unlikely anyone will ever check beyond normal MoT requirements.
I believe you're incorrect. AFAIK there is no inspection of bulb type in the MOT
The requirement for self-levelling and lamp washers was mandated for new cars fitted with HID/Xenon lights. It does not apply to earlier cars
Similarly it is not illegal to fit halogen bulbs to cars that were not originally fitted with them, nor it is illegal to fit electric lighting to cars that originally used carbide/acetylene lamps
Nick Froome
www.w124.co.uk
In summary it is not permitted to convert an existing halogen headlamp unit for use with HID bulbs. The entire headlamp unit must be replaced with one designed and approved for use with HID bulbs and it must be installed in accordance with the rules stated above.
From the horses mouth:
http://www.dft.gov.uk/pgr/roadsafety/drs/hidheadlamps
They can't make it any clearer than that!
From the Horse's mouth:
"The Road Vehicle Lighting Regulations 1989 regulate the situation in the UK.
Under these Regulations, HID/Gas Discharge/Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law"
So all HID lights are illegal in the UK?
The law here is a mess and I don't think anyone wants to go there. I would treat Construction & Use as being definitive and, as far as I know, HID/Xenon is not mentioned there
Please note I specifically did not say that HID was legal: I said that laws applicable to the construction of new cars do not apply to earlier cars
Nick Froome
www.w124.co.uk
Nick Froome
www.w124.co.uk
Under these Regulations, HID/Gas Discharge/Xenon headlamps are not mentioned and therefore they are not permitted according to the strict letter of the law.
However new vehicles have HID headlamps. This is because they comply to European type approval Regulations. The UK cannot refuse to register a vehicle with a European type approval. These are to ECE Regulation 98 (for the HID headlamps which are tested on a rig in a laboratory) and ECE Regulation 48 (Lighting Installation on the vehicle).
For the after market, a used vehicle cannot obtain type approval because it is only applicable for new vehicles. However we feel that saying "HID is banned in the after market" would not be reasonable. Instead we should make analogies with new vehicles. It would be reasonable to require HID in the after market to meet the same safety standards as on new vehicles. The same level of safety should apply.
Therefore a HID headlamp unit sold in the after market should:
1. be type approved to ECE Regulation 98 as a component.
2. when fitted to the vehicle should enable ECE Regulation 48 to be complied with (although no government inspection will take place).
3. Comply with RVLR as far as "use" is concerned.
In practice this means:
1. The headlamp unit (outer lens, reflector, bulb) shall be type approved to ECE 98 and be "e-marked" to demonstrate this. That can only be done by the headlamp supplier - Hella, Valeo etc. who must test the headlamp in an independent laboratory.
2. Once fitted to the vehicle it must have headlamp cleaning and self-levelling (which can be for the headlamp or can be in the vehicle suspension - some expensive estate cars have "self-levelling suspension" and that is adequate). Also the dipped beam must stay on with the main beam.
3. The headlamp must be maintained in good working order, kept clean, and aligned/adjusted correctly like any other headlamp.
