hole in exhaust pipe - mot question
Discussion in 'Engine' started by SilverSaloon, Nov 24, 2008.
  1. SilverSaloon
    SilverSaloon MB Club Veteran
    7,759
    Mar 16, 2004
    Car:
    1994 W124 E300D Estate, 1985 R107 280SL
    Hi
    my wife's picasso failed the MOT on a couple of things. One being the "rear exhaust is blowing". Quote for £80 from Kwikfit to replace, so i thought i'd have a look as you can get the part for £40 on ebay.
    Got car on ramps and the actual hole is on the pipe bit that the rear box connects to, so the middle section is the bit that would need to be replaced (no idea on price though).
    I spent £15 on a patch kit from halfords that contained some "metal putty" stuff and a roll of silver tin tape. Seems to have done the job.
    My question is that is a repair kit good enough (assuming it fixes the blow) to the car to pass then? or will they turn round and tell me the exuast needs changing?
  2. vijilants
    vijilants Hardcore MB Enthusiast
    2,225
    Jan 23, 2007
    London
    Car:
    C320CDI Sport W204
    As long as the repair is solid I see no reason as to why it should fail :)
  3. maddog
    maddog Hardcore MB Enthusiast
    725
    Dec 18, 2007
    truth is the exhaust does need changing a patch is only ever a temporary repair , should get you through the mot though
  4. OP
    OP
    SilverSaloon
    7,759
    Mar 16, 2004
    Car:
    I wasnt expecting it to fail on a hole to be honest so it took me by surprise.... once its through the MOT then i will buy the bits ready to replace, hopefully it will last until the winter is over.
    i'd prefer to fit myself and save the cash but would prefer to do it in my own time rather than 10 days before the retest.
  5. grober
    grober MB Club Veteran
    27,613
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  6. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    As long as it's not actually blowing it can't be failed.
  7. LoTu5
    LoTu5 Active Member
    69
    Nov 3, 2008
    Gravesend.
    Car:
    1976 Trans Am, 1973 Mach 1 Mustang & 2007 Mercedes SL350
    Easiest thing to do, once you've repaired it is put a couple of exhaust clips over the patch, try and get the clips with the flattened band, they should help seal it plus making it look better than just a patch aswell as helping you through the winter.
  8. Sp!ke
    Sp!ke Administrator Staff Member
    12,234
    Jun 2, 2002
    West London
    Car:
    SL500 & The Fart Car
    I usually use some exhaust jointing compound, an old baked bean tin (opened up and flattened) and some jubilee clips.
    £15 for a halfords repair kit, you were robbed :D
Share This Page
