hole in spare wheel housing w124 estate
michaelk3289
London
1999 W210 E240 Avantgarde
can anyone please advise if i should have a very small hole in the housing floor.
i took the spare out today and found it was wet on the bottom where it had been touching the floor
it sounds and looks to me like i have a leak and some corrosion but im hoping you can point me in the right direction
:dk:
BillyW124
North West London
W124 E320 coupe, W211 E320 V6 CDI, W211 E63 V8 AMG, R129 SL 280 V6, W215 CL 600 V12 Bi Turbo.
..i wouldnt say small but there should be a rubber grommet (hole) in the wheel well.. thats assuming the grommet has gone walkies and you are left with a hole?
pics would be better to distiguish..
renault12ts
MB Club Veteran
2005 W215 CL500.
Neat round hole with a rubber grommet is meant to be there. Jagged round hole, brownish in colour...rust. Not rocket science.
Not a vital place, you will not fail the MOT because of it since its not regarded as structural in that area.
OP
OP
M
michaelk3289
London
will try and upload pics, it was very grubby and all i could see what the floor below, couldnt make out a grommet or rust for that matter, i guess i should clean it and take pics
but now that you say there should be a rubber grommet that sounds like it may be that
thanks
BillyW124
North West London
grommet is in the middle-ish of the well, you will be able to make it out.
put it this way, if you see tarmac through the hole then you missing somthing or you got corrosion buddy
GP801
Sussex and Tuscany
2003 W209 CLK, 2005 R171 SLK in UK, 1995 S124 E280 in Italy
Check the other side aswell. There should be a grommet just anterior to the rear washer bottle. They frequently get blocked with muck. Also the rear side windows are a known place for water ingress as the seals tend to fail so its important to keep the drain holes clear.
BillyW124
North West London
yep ^ apparently very common on the estates with the seals at the rear
Egbert Nobacon
After rain, with the spare wheel removed reach up to feel the underside of the rear window area. If it's damp then that's probably the source. Worst case scenario it'll be crumbly rust......
OP
OP
M
michaelk3289
London
ah that didnt work
anyone know how i can attach a picture from my laptop
OP
OP
M
michaelk3289
London
i have found the drain it looks as if it has perished, i have take some pics but cant up load them at the min, i can see the gound through the drain
GP801
Sussex and Tuscany
The grommets are cheap and easily available from MB dealers. Whilst you are checking the drains there are 2 with cone shaped rubber grommets in the floor behind the front wheels. Also check the drains from the sunroof and the ones at the corner of the windscreen. The water should drain out behind the plastic insert under the front wheel arch.
BillyW124
North West London
Water drain doc
i have a doc that shows drain holes for various 124's helped me wonders.
attatched:thumb:
Edit: its too big! i'll email it to you..
OP
OP
M
michaelk3289
London
yep got it, many thanks
