- Jun 24, 2008
- Location
- London
- 2022 Hyundai IONIQ 5 RWD / 2016 Suzuki Vitara AWD
This is the background....:
For a number of years we had issues with rising damp in a few locations (it's a London basement flat), mainly around two radiators - we were advised that the warm water pipes draw-up the moisture into the wall.
One radiator was removed altogether and the wall was redecorated in the usual way, which was a quick fix that resolved the issue in that particular location (the radiator wasn't really needed there anyway).
For the other radiator, we brought-in a damp proofing specialist firm. They quoted for a repair, including the removal of electric and data sockets, and removal of the radiator from the wall. Their quote did not include redecorating, refitting of the electric sockets, or refitting of the radiator.
On the agreed date, their team attended site, and their electrician and plumber removed the sockets and radiator. The wall was then damp proofed.
They then further quoted for an electrician and a plumber to attend site and refit the sockets and radiator. They quoted a reasonable hourly rate (rather than a fixed price). The electrician came and sorted the sockets, and this is fine.
However, when the plumber came, it turned-out that the firm used external contractors for plumbing, and the contractor who came to fit the radiator wasn't the same chap who removed it.
The bottom line is that he said that the radiator cannot be refitted... apparently the issue is that when the wall was broken, it was possible to move the pipes slightly sideways and backwards to allow for the radiator to be removed, but now with the pipes firmly fixed in the newly-repaird wall, he was concerned that trying to bend them will result in either the pipes breaking, or the new wall breaking. He said that '20 years of experience' tell him that he shouldn't be attempting this.
He then submitted a report saying that the issue could be resolved by fitting a different joint on the pipe's end, but in order to do that, the heating systems will need to be drained (the bit that needs to be replaced also hosts the insulator valve). In short, he says that the current fitting at the end of the pipe isn't the correct one for the application (that radiator is 'relatively' new, but was fitted around 10 years ago).
But, because some if the radiators are quite old, and the bleed valves have been painted-over, he added that if the system can't be properly bled after refilling it, then those older radiator will need to be replaced too.
We suggested that perhaps a narrower and taller radiator will resolve the issue, and the plumber is happy to try and fit it for us if we can source one, but the risk then is that if he can't fit the radiator that we buy, we will now have two radiators that we can't reuse......
Any suggestions will be most welcome! Thank you in advance....
