Home router query
Discussion in 'PC and I.T support/Advice posts' started by jukie, Mar 29, 2014.
  1. jukie
    jukie Hardcore MB Enthusiast
    1,130
    Jan 16, 2003
    NE Cumbria
    Car:
    MY11 E350 CDi Avantgarde
    Do you turn yours off when not in use or leave it on 24/7?
    Pros and cons?
    I currently turn mine off when not needed but if it's more beneficial to leave it on, I could be persuaded!
  2. IanA2
    IanA2 Hardcore MB Enthusiast
    4,533
    Sep 17, 2003
    East Mids
    Car:
    SL60 AMG, GES300, Lexus GS 430
    I leave mine switched on 24/7. To be honest it's never really occurred to me to turn it off. :dk:
  3. Ten elena
    Ten elena Hardcore MB Enthusiast
    181
    Feb 7, 2014
    London
    Car:
    1998 R129 SL500
    Same here
  4. markjay
    markjay MB Club Veteran
    16,971
    Jun 24, 2008
    London
    Car:
    W204 C180 Executive SE 2013 Automatic / COMAND NTG4.7 and Morel speakers fitted by www.comand.co.uk
    I suspect that most if not all routers are left on 24x7.
    I suppose there is a point however to consider regarding energy waste... as is the case with AC adapters that are left plugged in, or TVs on standby, etc..
  5. ioweddie
    ioweddie Hardcore MB Enthusiast
    860
    Sep 16, 2012
    Winford Isle of Wight
    Car:
    AMG Line Premier Plus Estate C220d
    mines on 24/7
  6. brucemillar
    brucemillar MB Club Veteran
    7,718
    Nov 18, 2010
    Next Door to Alice - 25 'kin years now
    Car:
    C55 AMG Wagon - W124 300te 4matic Wagon - BMW 4.8is X5 E53 - SWB Pajero 3.5 V6 24v
    Always on.
  7. Danny DeVito
    Danny DeVito Hardcore MB Enthusiast
    886
    Nov 1, 2009
    Ireland
    Car:
    V220 CDI
    Do you know how an ac adapter uses power while left plugged in ?
    My isp tells that router should be left on to prevent the network thinking its dropping out
  8. Druk
    Druk Administrator Staff Member
    5,309
    May 28, 2004
    Not far from Edinburgh.
    Car:
    2011 S212 E350CDi. 1981 R107 300TurboDiesel.
    ^ wot they said.
  9. Giantvanman
    Giantvanman Hardcore MB Enthusiast
    3,809
    Dec 7, 2013
    Essex
    Car:
    FFRR 4.4 TDV8 Autobiography
    ^and me. Plus ISP sometimes run updates during the early hours.
  10. daveenty
    daveenty Hardcore MB Enthusiast
    2,811
    May 12, 2007
    NW UK
    Car:
    W213 E63s, W201 190E 2.5-16
    Another good reason for leaving it on is that it will keep your maximum speed up.
    When it gets spotted by the ISP that a router is turned off, it makes an assumption that the lack of connection is due to a failure on it's behalf. It therefore turns down the SNR and hopes that this will cure it. If it sees lots of disconnections it will start to slow the speed right down.
    Not too bad if you have massive speed to start with, but for people like me on low speeds it can be a nightmare.
    1 person likes this.
  11. Piff
    Piff Hardcore MB Enthusiast
    1,756
    Feb 24, 2005
    Suffolk
    Car:
    Mitsubishi L200 Barbarian, A207 E250CDi Cabriolet Sport, R171 SLK280
    on 24/7
    so many things using it now - pc, mobile phones, tv, sons!
  12. BTB 500
    BTB 500 MB Club Veteran
    17,504
    Aug 7, 2005
    Berkshire
    Car:
    R129 SL500, W639 Vito 120, S203 C230
    Used to turn the old one off overnight to stop the kids using iPads / phones / etc. until the small hours. But the BT Infinity one I have now lets you set start/end times for internet access for each individual device that connects to the network :thumb:
    So now it's left on 24/7.
  13. OP
    OP
    jukie
    1,130
    Jan 16, 2003
    NE Cumbria
    Car:
    Thanks all. Seems I was in a minority of one!! lol
  14. markjay
    16,971
    Jun 24, 2008
    London
    Car:
    Yes - an AC Adaptor is a power transformer and uses induction - the primary coil is always drawing current even when the secondary coil's circuit is open.
    It is a small amount - but similar to electronic equipment on standby, it has been suggested that if everyone unplugged idle AC adaptors the cumulative effect will be significant.
    I don't have a view regarding which is best to do - just trying to contribute relevant information.
    Another interesting point is that electricity as a form of energy is mostly turned into either kinetic energy, light energy, or heat thermal energy - and in case of an AC adapter where there's no kinetic or light energy, the power is simply converted into heat. If an AC adapter is warm to the touch when no device is connected, that's the power it consumes.
  15. Danny DeVito
    886
    Nov 1, 2009
    Ireland
    Car:
    V220 CDI
    Thanks, thats interesting at least its tangible proof. Can't say i have ever noticed an adapter giving heat while disconnected from equipment but i can see the point of energy change. I would imagine the power use on a say a phone charger is negligible. I may stick the meter on an extension lead and test some time for a real time answer. I have a lot of chargers and power supplies around the place. When i get to it i will report back. Currently busy with beer can whirlygig test.
  16. John
    John MB Club Veteran
    10,090
    Mar 3, 2011
    Daan Saaf
    Car:
    CL500
    I turn mine off purely because when I turn my computer off, the monitor, PC and router are next to each other on a individually-switched extension lead.
    I have no need to leave it on when neither of us are using it.
    I have no issues as a result and my connection speed is mostly consistent.
    The flip side is sometimes routers left on forever start to misbehave sometimes in my experience, which is fixed by a power cycle.
    Each to their own!
  17. Rory
    Rory MB Club Veteran
    7,059
    Mar 12, 2005
    Cheshire, UK
    Car:
    C270CDi Estate (2004 facelift model)
    I started turning my printer off as I hardly ever print anything these days. Then I came to use it and a print head had dried up - the machine normally cycles itself every few days. Spent ages trying to get it working again but had to buy another head.
    I think, generally speaking, it a bad idea to power cycle electrical equipment. It'll last longer if it's just left on.
  18. Dieselman
    Dieselman Banned
    34,206
    Jul 13, 2003
    Car:
    Peugeot 403 Convertible
    I switch off when not in use.
Tags:
Share This Page
