I’m having problems with my home wifi.
My broadband supplier is Sky, and I’m on a fast fibre deal (FTTC). The exchange is only about a quarter of a mile away, and the cabinet is 75 yards. My wifi router is in my living room, and at most 15 feet from my laptop in line of site. The only other items connected by wifi are my tablet and my mobile – the tv is connected via cable.
In the past, I’ve usually had download speeds on wifi of around 75 MB, and uploads of 19 MB. Over the past few months this has regularly dropped to around 5 MB download, and 12 MB upload. This drop in speed is on all devices connected via wifi. If I connect my laptop via a cable, I get the high speeds I used to get, so I decided it must be a problem with the router’s signal output.
I spoke to tech support at Sky, they got me to change the channel on my router. There was still no improvement, so they sent me a new one (Model ER115, if that helps). The problem is still the same.
I’ve tried setting the channel manually, choosing a few at random and doing speed tests, and it seems to best on Channel 10 where I get about 30 MB down, and 19 up.
Is there anything else I can do? I’m guessing that there’s something in the area (outside my flat) causing interference, which would account for the fact that I used to occasionally get my former speeds when I left the channel selection on auto. I don’t really want to run an ethernet cable to my laptop; it doesn’t really help the portability!
