horn problem (w124)
Discussion in 'Electronics' started by mattc, Oct 28, 2008.
  1. mattc
    mattc Hardcore MB Enthusiast
    2,579
    Sep 27, 2007
    Midlands
    Car:
    2003 E270 avantgarde, 1994 E320 Coupe
    what will have gone wrong? The horn Nat's estate only works when you press the left side of the wheel; nothing happening on the right - why would that be?
  2. SilverSaloon
    SilverSaloon MB Club Veteran
    7,759
    Mar 16, 2004
    Car:
    1994 W124 E300D Estate, 1985 R107 280SL
    You're best bet is to take the airbag off (2x Torx screws from rear of wheel) and checking the metal bracket behind - its probably not making the contact - also a wire may of just come loose. All will be revealed once the airbag is off
    make sure you disconnect your battery before disconnecting it though!!
    The pic attached shows the inner of the wheel - the black vs the silver metal bits at the side is what detects the pressure of the horn-press. probably not making contact or wires loose. your 124 will be very similar inside to this. Thinking about its, (cant remember off hand) its possible that the horn goes off when the contact is broken, rather than when the contact is made.... compare against your working side
Tags:
Share This Page
