aquilaalba
Hi peeps! I've acquired a 2002 W163 ML270 CDI - car that was a non-starter, dead on arrival. Found few problems so far - some might help someone, hence the thread, will add a question at the end of the topic. It turned out to be a dead battery and someone put the 100A block fuse on positive battery terminal incorrectly - it was wire straight onto bolt, then fuse (blown) and plastic nut. That contraption wasn't making proper contact, so ended up replacing it (temporary with external maxi fuse box). Then I found out the coolant and glow plug lights would stay on. After connecting to diagnostics it was coming up with glow plugs and loads of other messages, also coolant temp was showing -40C. When I was looking for sensor to replace it, I found out that it was disconnected, so if it shows -40C, check plug and wiring. Next I had to add almost 7 litres of distilled water to coolant, didn't expect to add this much, but wasn't sure what colour coolant was used previously, so added water. It runs now with no lights after deleting errors, only ones left are two for left mirror, worrying one is B1108 - M13 Heating water circulation pump M2/2 Module box blower motor, B100A - M2/1 Rear blower motor, B1206M2/12 rear shut off flap position motor and lastly C1401 A7/3m1 High pressure and return pump.
What was odd, when I've replaced 100A fuse, the rad fan was on full blast constantly, rad light was on and codes were present P0115-2 (coolant temp sensor), P1482-4 (glow output overcurrent), and 2, 4, 5 glow plug failure. Connecting the temp sensor cleared the codes, don't ask me how, also the fan gone back to normal. Now I've got a coolant leak, weird as it's not very consistent, seems to weep from under the washer bottle area, thought it was that to start with, but seems to leak coolant. Will check tomorrow, but so far it runs and seems way better. Also oil is a sludge, not really oil, local servicing policies here I guess. Anyhow, wondering if it didn't cook the head gasket with that much coolant missing, will try to find where it's leaking from and change oil. The contraption on positive post was all backwards and was not making proper contact as it was all loose, hence I had the car as a dead lump. Looking forward to getting this back right, but why do people neglect cars this much in the first place? Is there any place where you can find an online PDF of service manual for these?
