Good morning,
For reference really.
I have been having a terrible problem with brake judder when high speed braking. And it gets worse the more I drive the car. Initially I did the usual checks: Clocked all 4 discs with a DTI, Calliper and pins checked and suspension for any signs of wear. all proved fine. Then I read on the net about DTV (Disc Variation Thickness) which causes the discs to change size. After another week I took the plunge and replaced the front Discs which were less than a year old and no more hot judder. I took my time bedding in and after 500 miles and a few spirited drives the brakes are great.
Discs I took off were Pagid and I replaced with the same. Hopefully the problem will not reoccur!
Simon
Simon
