Hot running (not)ish
Kinky
Berkshire
All sorts of odds n sods
I've seen a million and 1 postings on various sites (this included) regarding the temp gauge and high temperatures, etc ....
I have a specific problem which I've not seen documented elsewhere but would be interested in anyones thoughts.
Casually moseying down the M3 at varying speeds of a morning or evening my temp gauge will happily sit at anywhere between 80 - 100.
However, as quick as a flash it'll jump up to 120+ (I say + coz it looks like the needles goes as far as it can.
And you can sit there watching it literally jump up and down between 80 - 120+ like it's on a spring bouncing up and down. There's no (apparant) correlation with revs, speed, throttle, what electrics I have on, having heater on full hot blast, air con, etc.
There's no apparant or obvious leaks anywhere - the coolant is a nice kind of minty artic blue colour, and the oil cap is nice and clean and as expected. The oil (from what I can see) is nice and clean.
When I got the car I was told about this and the fact that the dealer had it pressure tested and it was ok.
As I've now got the car going in for a main dealer service on Saturday - any pointers on what to check for - or what I should have replaced?
Fortunately it's under warranty so if it's major - it "should" be covered.
Many thanks in advance,
K
[Edited to say it's a '93 L E280 estate with 122k on the clock]
[and re-edited to say that it's been serviced pretty much bang on the nail every time - but not by an MB dealer - or even an 'expert' from what I can guess]
jimmy
Northamptonshire
Discovery 3 TDV6, Discovery 300TDi - Plaything!
Sounds like a faulty sender switch or some other electrical fault. You could actually get a thermometer and check the accuracy of the gauge, if its reading 120+ surely you would see steam rising from the bonnet?
Steve_Perry
Wales, U.K.
CLS350CDI Grand Edition
I had exactly the same on my previous '86 190E only in that case it was the pressure gauge that read from 0-3 (bar?). It was jumping around like a yo-yo, the problem was caused by a faulty sender unit. The replacement unit was quite cheap too :)
Heh with the current car I wouldn't get that problem as they did away with the pressure gauge, and the economy gauge has disappeared too. That's progress for you :rolleyes:
S.
fuzzer
Glasgow
F25 X3 20d SE
My car does not have a temp gauge on the dash , you have to go through the computer to get it on screen and ive not got a dipstick either , its all done through the dash cluster.:confused:
RichardM
Essex
2011 CLS350 CDI
I've got a temp gauge, although its an electronic bar chart, no dip stick though.
kid-jensen
Epsom Downs
ML 320 W164
I'd suspect the gauge itself.
If it's under gaurentee, get them to replace it, or explain EXACTLY why it can't be that ;)
