I have hot water in the header tank (F&E) to my vented central heating system....this has happened recently. As far as I can tell, the rads are getting hot.
Any ideas
Is the system making any unusual noises. Pumping over or kettling would be my guess too. Maybe the boiler stat is faulty.
I had a problem with hot water venting from my pressurised hot water cylinder - the internal cold water tubing had split leading hot water to pour out continuously from the tank out from the overflow, which caused a lot of water damage to my roof. I needed a new hot water cylinder, all because the original installer had not put on an expansion tank but had connected it to a pressurised cold water tank, meaning no expansion was possible.
