Uncle Fester
water is pumped around the panel from the drain back unit which transfers that heat to the unvented hot water cylinder, when the system is off, it makes no odds how efficient the panel may or may not be, as the system is off.
I'm not sure if they have any installed in Scotland, but I'm sure they'd tell you if you asked them.
The panels are made of aluminium sheet with 10 mm copper tube lazer welded to the collector panel.
