How alarm can get disabled on e-class?
maxima
London
W211
I have this car since 2005. it is W211. I never had this problem before. I went to local shop and when i wanted to set the alarm - nothing happened. i tried few times. when i pressed 'open' button - it flashed once. however 'close' didnt work at all...
once i came back home it worked as usual.
can it be some strong radio signal interference around that particular place which was screwing the keyfob?
(need to note that i even sat inside the car and tried to set the alarm from inside - hoping it will reduce interference somehow).
grumpyoldgit
Stourbridge
C270CDI Avantgarde SE
Have you checked the batteries in the fob?
BlackC55
Portsmouth, Hampshire.
E55K SL500 E300Hybrid E250X3 Viano C55 E450Cab A180 Smart 44 Brabus
Radio interferance can cause this type of fault.
As above, check key batteries. Try using the spare key for a while and see if you have the same issue.
OP
OP
M
maxima
London
W211
is nothing wrong with the batteries. as i said - close button worked - it uses the same battery right
also I went home 20 min later - and all button was working..
renault12ts
MB Club Veteran
2005 W215 CL500.
Don't be so quick to dismiss the advice above. Just because it locks the car does not mean the battery is fine.
sinewave
Cheshire
BMW 520 M-Sport Touring, Kawasaki ZX10R KRT (AMG Eater!)
Didn't you spot the Oiks parked up close by with the Radio Jammer and reader who remotely jammed and code read your Key Fob for future stealing to order?
No??
Oh well, keep an eye out tonight! :eek:
Dieselman
Banned
Peugeot 403 Convertible
If the car thinks a door isn't shut it won't arm the alarm or operate the central locking.
Just a thought.
OP
OP
M
maxima
London
W211
something like that crossed my mind (this is why I actually went here to ask). it was few teenagers around on the feet. Sudanese asylum seekers. but they went away soon and the alarm still didn't work..
however could you please tell - why would they need to jam in order to read the code? do you have a link to an article which can explain this technology in better details?
Dieselman
Banned
They jam the radio code so the car doesn't lock. Most people don't notice.
As it worked for unlock, I doubt it's jamming.
OP
OP
M
maxima
London
W211
we'll see. if it is not stolen in a month then it was probably nothing.
Dieselman
Banned
There is no scanning going on here and almost certainly no jamming either.
Even if the RF code was scanned, the car couldn't be driven away.
sinewave
Cheshire
I was joking before this 'gets outa hand'! ;)
OP
OP
M
maxima
London
W211
my 2nd wife used to say - in every joke, there is a pinch of joke.
OP
OP
M
maxima
London
W211
that was the point yeah ;)
