Troon
Any ideas, without crawling under the car?
developer215 said:There are members on here who can send you the datacard based upon your VIN number, if you ask for it - it's useful/interesting to have regardless.
Some will direct you to the Russian VIN input site but I understand it can be incorrect in some cases.
Ask the question and I'm sure someine will provide.
Who would you recommend to ask?
amilli1 said:Hi guys ina bit of a pikkle here i bought a 2008 c220 cdi sport without knowlage of deisels i was advised a deisel as they last forever but im not sure if it has a dpf or not the exuast is a bit sooty inside so does that mean it dosnt have one??? cheers guys
Its pretty easy to tell just look at the exhaust outlet, I dont have one on my 2007 W204 220 CDi and after a decent journey its certainly noticable with black soot in abundance so if you have a DPF you wont see that.
Honest John motor website always says something against DPFs but as long as you dont poodle about all the time you should never experience a problem, you will certainly benefit from lower road tax Im sure as mine is £190 a year
The important bit though if you do determine you have a DPF is that you MUST use the correct oil, no DPF is a little more flexible with regard to engine oil
