how can i tell if my radiator bottle has anti-freeze?
Discussion in 'Engine' started by Sir Chumpalot, Nov 15, 2010.
  1. Sir Chumpalot
    Sir Chumpalot Hardcore MB Enthusiast
    104
    Sep 27, 2010
    hi all, cold nights are most defanantly setting in now, and wondered how do i check if my radiator bottle has anti freeze in or not? it is a clear solution, so could just be distilled water and nothing else....
    many thanks
    James
  2. Sp!ke
    Sp!ke Administrator Staff Member
    12,234
    Jun 2, 2002
    West London
    Car:
    SL500 & The Fart Car
  3. OP
    OP
    Sir Chumpalot
    104
    Sep 27, 2010
    thanks spike, and if it does need some anti freeze in, what is the easiest way to drain the coolant so i have room for the anti freeze please?
    thankyou
  4. killwilly
    killwilly Hardcore MB Enthusiast
    120
    May 12, 2010
    South Lincolnshire
    Car:
    CLC 180 Sport
    Save your cash, just syphon a drop out and bung it in the freezer. :D
  5. nickcc101
    nickcc101 Hardcore MB Enthusiast
    355
    Aug 4, 2007
    Helston Cornwall
    Car:
    2001 S203 C180 auto estate (sold)
    Antifreeze also loses it's anticorrosive properties over time so should be changed every 3 or 4 years (my opinion). After a total drain (as much as possible) you should refill with a mix of 50% tap water and 50% neat antifreeze, distilled water is only used in batteries (or my Wifes :) steam iron)
  6. kwakdonut
    kwakdonut Hardcore MB Enthusiast
    2,744
    Jul 22, 2006
    Highworth, Wiltshire
    Car:
    Frod Mundano TDCi, Kawasaki z650
    Tap water is fine if you live in a soft water area but definitely not if you live elsewhere!! I have always used distilled water for coolant top-ups/replacement with no problems. It is worth it to avoid adding another potential problem....
  7. Sp!ke
    12,234
    Jun 2, 2002
    West London
    Car:
    I use Britta filtered water in my coffee machine, my kettle and my wifes iron and they do not suffer from lime scale at all.
    So the car gets Britta filtered water too. :D
  8. OP
    OP
    Sir Chumpalot
    104
    Sep 27, 2010
    thanks guys, can anyone recommend a decent anti freeze please?
  9. Sorry Pete
    Sorry Pete Hardcore MB Enthusiast
    459
    Dec 13, 2007
    London
    Car:
    a most boring Honda
    Hi, try this family of antifreezes from Comma:
    Link
    I've used the yellow, G05 stuff in my 300D and in the 300SL without trouble. The G05 is the same as Valvoline Zerex (if the peachparts US forums are to be believed) in the USA, which was what 1980's MB's were filled with from factory when they were exported there.
    There are data sheets with the MB approval spec number. Ensure it matches or exceeds that which is specified for your car. You don't mention what model you drive, but afaik, the G48 (green) stuff is widely used by MB owners, contains silicates and is good for 3 years.
    The red one is silicate free, and is the long-life variant - good for 5 years. I think members have used that or similar without trouble as well.
  10. Sorry Pete
    459
    Dec 13, 2007
    London
    Car:
    a most boring Honda
    I also use distilled water you can get from Robert Dyas to fill irons and the like. It's not worth the hassle of a potential water gallery furring-up and for me, it's a £2.99 insurance ticket against bad things happening to the engine.
    Oh, and the easiest way I heard of testing to see if there's coolant is the taste test - antifreeze has a bitter sweet saccharine additive / property. Obviously don't start guzzling from the expansion tank!
  11. SilverSaloon
    SilverSaloon MB Club Veteran
    7,759
    Mar 16, 2004
    Car:
    1994 W124 E300D Estate, 1985 R107 280SL
    thumbs up for COMMA GREEN antifreeze from me. Meets MB Specs.
    however, my brother has Adsa's own brand BLUE in his Corsa and hasnt had any problems.
  12. tagnut
    tagnut Hardcore MB Enthusiast
    391
    Oct 28, 2010
    East Yorkshire
    Car:
    '03 E320 CDI Avantgarde
    Please don't "test" your antifreeze like this. Despite the sweet taste it is highly toxic and can cause renal failure, cardiovascular failure, brain damage and death :eek:
    1 person likes this.
  13. Scott_F
    Scott_F Hardcore MB Enthusiast
    4,091
    Mar 12, 2010
    Apart from that is it safe though ??
  14. kwakdonut
    2,744
    Jul 22, 2006
    Car:
    Totally :D
  15. JOB-BLACK-RAT
    JOB-BLACK-RAT Hardcore MB Enthusiast
    1,127
    Oct 17, 2010
    Near London
    Car:
    BMW 5 series 'ahem'
    Oh know one siad yeo covldnt drenk it, byt it taest so goud and neuer dune me ayn hram
    7 people like this.
  16. grober
    grober MB Club Veteran
    27,603
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
    Why not use the pukka MB antifreeze? Its not that expensive.
  17. Sorry Pete
    459
    Dec 13, 2007
    London
    Car:
    a most boring Honda
    Pretty sure Dieselman thought Comma were OEM installed by MB, so the same stuff without the markup. :dk:
  18. grober
    27,603
    Jun 22, 2003
    Perth, Scotland
    Car:
    W204 C200CDI Estate
  19. ss201
    ss201 Hardcore MB Enthusiast
    839
    Aug 29, 2009
    Near Lancaster UK
    Car:
    190E 2.6 Sportline, W203 320 CDi SE Estate
    If you live in a hard water area and are concerned about the water you put in your rad or iron - use the water from a de-humidifier.
  20. OP
    OP
    Sir Chumpalot
    104
    Sep 27, 2010
    repl
    I have a w203 kompressor mate, the radiator bottle is totally clear, so has no anti-freeze, when filling up with anti freeze, is there anything else i need to do to prevent air locks ? and where sorry can i find the data sheets with the MB approval spec number so to get the correct anti freeze?
    many thanks
    James
Share This Page
