How do I access the Cigarette Lighter to replace defective unit?
dpg1962
Can anyone advise how I access/remove/replace the entire cigarette lighter unit on a W210 Mercedes E Class Estate? I have purchased a replacement unit and just want to fit it.
Any guidance would be most appreciated :)
looked on the epc...
looks like you remove the actual ash bit - as in when emptying - then underneath is one phillips screw...
If only I could get my EPC working.....
I took a look after removing the "ash bit" but aalas I could find no screw....could you tell me where this should be..... :confused:
maybe under part 600?
edit - ah - screw 630 - two off. so i presume they are at the back of the unit, so you have to remove 650 / 655 first..
Sorry Guy, but what is part 600?
Sorry I can see your image now...I could'nt to begin with....damn comouters...I don't think they'll catch on!!! :)
Now all I have to do is work out how to remove 650 / 655....without causing damage :crazy:
If it's anything like the w202, you have to remove the armrest first! :)
Thanks Shude but I suspect it is nothing like the w202 as it is nowhere near the armrest look at the pic posted by Guy and you can see clearly..... :rolleyes:
The w202 ashtray isn't anywhere near the armrest either, but it shares a pair of screws with it!
