Beetnik
Hi - first post - just bought a new SLK 200 in part as we're heading for a tour of France shortly. So to my question - how to convert the headlamps for driving on the left - on a temporary basis?
You can also buy, from Halfords etc, stick on convertors that change the dip from left to centre/right.
Open the bonnet and have a look at the rear of the headlights. You might find a lever behind the dipped beam housing when you remove the cover. If so slide it till it either gives you a horizontal beam or a beam pattern kicking up to the right (for France/Europe) If you ask your MB dealer they should do it for free (3 minute job)
Yes it's typically only xenons that have an adjustment lever.
If you travel to the continent regularly one ruse is to have a set of headlamp protectors permanently fitted with the sticky mask things. Then you can just fit/remove at will.
For occasional driving, if your car has manual beam level adjustment you can just lower the beams slightly. Not ideal, but better than blinding oncoming drivers.
I have the adjustment levers on mine which are not XENONS. Also I can't beleive a new SLK does not have headlamp dipped beam adjusters for driving in mainland Europe ?
Beetnik, we take ours to France quite often and decided to ignore the correction and choose never to drive in the dark in France. We have to set off so early from home we need them in the UK setting [normal] for the early morning part of the journey and by the time we get any sensible distance in France, the last thing we want to do is get back in the car. So, we drive in daylight over there only and if we need lamps for poor weather or rain, we just use side lights and the fog lights which are low and don't cause a problem to oncoming frogs. This only works if you don't need to drive at night, but we think the food is too good to miss so don't drive over dinner time. Just a thought!Hi - first post - just bought a new SLK 200 in part as we're heading for a tour of France shortly. So to my question - how to convert the headlamps for driving on the left - on a temporary basis?
That's certainly true for the W204 non-HID setup. A lever inside the headlamp assembly moves a mask over the beam to give a symetrical cut off.
