How do I remove W210 estate bumper????
Don777
CLS63 c218
Has anyone removed the bumper on their W210 estate? Could you post the how you did it please, I'm about to install parking sensors.
Thanks.
Don, did you get anywhere with this? I'm about to do the same.
My guesses are that the arch lining and rear boot trim panel need to be removed.
There are some bolts/rivets that need to removed from the bumper that can be accessed when the arch lining and rear trim lining has been removed.
Nick,
I haven't actually done it yet, but I'm contemplating it tomorrow. I found the following on another forum, but I think it's referring to a saloon as opposed to the estate -
One stuck into this its quite easy should take no more than about an hour
Tools required
solder iron
braddle
socket set
Flathead screw driver
Hole cutter (generally supplied in Reverse alarm Kit)
1. Fit Display in Front of vehicle (I fit Mine above the right side air vent Below the speaker)
2 Feed the wire to rear of vehicle hiding under carpet trims to rear of the car
3 Remove Boot mat and trim fronm rear of boot, by prising the plastic plugs gently with a braddle
4. In The middle of where you removed the trim is a bolt undo this with your socket set but not fully yet
5 either side of that bolt hiding just behind the lining of the boot are two more again slacken them off but do not fully take them off yet
6 Gently pull the bumber free on the bolts (note the front ends of the bumber are guide rails by the wheel archs)
7 Once the who bumper is free to slide then undo all three bolts and remove bumper (placing a rug on the floor heer can prevent you accidently scratching the bumper
8 Once you have the bumper removed you will notice that on the inside there is markings for the 4 sensors location
9 Using the Hole saw drill from inside out for your guide hole, the drill from outside in to complete the hole, This leaves a much neater finish.
10 pop in the sensors accordingly (do Not Refit Bumper yet )
11. remove the bracket that the Jack Clips into and then feed the sensor wires through this hole into the boot
12. place two wires either side as you replace the jack clip
13 plug wires into sensor junction box
14 remove revese light bulb holder located on tailgate, and solder a wire to the holder for your + power feed this can be hidden under the boot lid liner then down the lid hinge and into the boot.
15 Connect the ground to the boot floor
16.Power up system and check the sensors work b4 replacing bumper
17. assuming all is ok, the slide bumper back onto guide rails pulling in the slack on the sensor wires
18 Refit the 3 nuts to secure the bumper
19 replace boot trim
20 enjoy your new reverse alarm
Hope it helps...we'll see,
Don.
Excellent, many thanks. That's just what I needed. I was going to look at it last night, but I went diving instead!!
