Hello,I have cl500 2000.Can someone explain me stupid how that kick button works after the pedal? So I push pedal to the end till I click it,and then what? Its like sport button near gearbox in newer mercedes or it does something else? So lets say if I start from 0,pushing pedal to the end is not efficient,so I guess I push to get some speed and at 2nd gear I hit the pedal so it downshifts and gives more boost? Nah this sounds like an accident with wheels spinning lol. Do you have to push it and can hold it and it will boost after some time or you have to push it just to enable the mode and then drive the car how you want it?
I felt car is kind a sluggish and sometimes it jumps a bit funnier.So I guess its little sluggish without that button,and after that button it reacts faster.I usually just push the pedal to the end and thats all lol...Not the best driver,live and learn I guess.
So how to use that button if I wanna start from 0,hit it driving before start,and then stop and start,or after button reacts it will spin the wheels because button is pressed and I should gooo without releasing it and it will be active,or I need to press,release it a bit,and then press again and goo?
What about drift,so you get 20 speed,press button and then when its activated I can try drift with wheels spinning faster? Help the nob.
