MattDC
HI all
I have a 2010 W204 C220 estate, elegance model.
I have fitted 18" AMG wheels but the ride height is looking a little 4x4 at the minute, I have been looking at the H&R springs to lower things but I don't want to compromise ground clearance too much.
The H&R springs come in 2 flavours a 20mm lowering and an extra low version which I think is 25-30mm lowering.
Also the standard 20mm versions come in 2 flavours for the front Axle weight, listed as up to 1020KG and above 1021KG, on the door frame the plate indicates a weight of 1055KG for the front axle so am I right in thinking I would require the 1021 and above or does the plate indicate the fully laden GAWR rather than unladen GAW?
Has anyone fitted the 25-30mm springs and if so what have your ground clearance experiences been like? Also has anyone fitted the 20mm springs and have a picture they could share to show how it looks?
Cheers
Matt
Cheers
Matt
