how much oil?
beaucostil
having oil change done at indie who doesnt mind me supplying own oil , ,was going for millers fully synth but unsure exact ltrs needed , , ,any idea?
To give you a rough idea, I put about 7-litres in my 124. Yours may need a little less though, I'm not sure.
According to the Castrol site, it's 8 litres. In case that's the initial dry-fill figure (unlikely, but . . .), start with 7 and check the dipstick, as refill quantity is always less than maximum capacity, sometimes a litre or more less.
http://tinyurl.com/4pd4ym
Unless you manually drain the oil cooler as well. I'm probably going to fit a tap for this to save undoing the union each time.
