Gazwould
Genuine , made by..
Lol , so much for the simple service and planned boost hose fix this afternoon...
Think I'll be driving the Merc tomorrow .
Hi everyone, I have a w245 and a w204 (OM640 and OM651, both diesel). I change the oil accordingly to the trips and usage, number of cold starts, stop&go traffic, dpf-regens, urban or not, etc. I don't exceed 5000 miles. The OM640 (euro5) has serious issues of diluting oil with diesel, so I change it even 3 times a year. I use Fuchs Titan GT1 Pro Flex 23 and Genuine oil and filters. Bye!
Hi! Thanks for your answer! I know very well dpf-related issues, I'm not a mechanic but I do a lot of jobs on my cars. I prefer DIY ;-). In reality I posted my witness on this thread not to start a dpf-discussion (I didn't want to obstruct the thread with something not related) but only to give one more report about services intervals on the forum . I can tell you that the 651 doesn't suffer oil dilution. It's quite perfect, oil doesn't move by 1 ml in a year. I do 12-13000 miles per year, but I don't exceed 5000 miles between oil changes generally if I can. The OM640 is known for the issue, even my old OM640 I had was in the same condition. I've already changed the timing chain, so now I keep the oil fresh to not repeat the labour. I've known many people here in Italy with the problem. So, despite I try to make the best usage for a diesel car (oil running for long on operating temp etc), it's often not enough. It's a "feature" of first euro 5 engines, unless you do 200 miles per day it'll dilute anyway I think. There are many scientific reviews about diesel oil dilution, above 5% dilution is considered hostile for engine, so I keep it under this threshold.
Absolutely no problem! With the 651 I do many trips of 15-20 miles and some rare 500 miles trips. But I saw that even with bad usage (short repeated trips and many cold starts) till now it didn't give issues of oil dilution. But the car is relatively "fresh" (only 85k miles). For the OM640 I check weekly the oil level, when it starts growing I aspirate some of it, but when about 300ml has already gone into the oil I change the oil entirely, because we are at about 5% dilution. No one ever gave me a decent explanation, but some MB technicians told me that engine has the issue. I don't think I'll keep the car for long because of this problem.I misunderstood the part about the 5'000 miles.
Exactly, sadly few cumulative hours of dpf regen are enough to dilute oil to the threshold point. Few long trips (5-6 hours at operating temp) can make evaporate a good percentage of fuel but at a certain point it's not sufficient anymore (this is what reviews report and also what I saw from experience). Have a nice day [/QUOTE
So if I ( or anyone else ) drive a vehicle which is suffering from diesel contaminated engine oil hard for several hours and 100's Miles, the high temperature will evaporate (some if not all ) the diesel from the engine oil ? That's a very interesting point. Such a drive would also give a complete regen, which seems to be the root cause of the diluted oil.
Yes, diesel evaporates at a certain rate at operating temperature. OM651 if I'm not wrong has an oil op temp of about 100/110 °C, so it's even easier I suppose. Long trips "purify" oil from moisture, contaminants and fuel, but within some limits. After a number of this purifing cycles, the fraction of biofuel of the diesel which can't vaporize remain in the oil inevitably. They also studied how oil would become starting with a very highly diluted oil running a number of cycles at certain rpms/load etc. They found that piston rings and chain were the most affected components due to dilution. This is what I remember
I don't think you have to be so strict about it. It's also a waste of fuel. These things are valid for every diesel the 651 doesn't have so much issues with dpf, unless you do for months and years trips of 5 miles at cold. Just drive it without all these concerns, check oil level to ensure it's ok and you are fine. Thanks to you
