- Nov 29, 2002
- Location
- London\Essex
- E63s s213 2019, E55 2004 Silver-SOLD, E63 w212 Weistec AMG-SOLD, E55 2004-SOLD, C36 1997-SOLD
Just getting round to tidy up the pics I have and came across these so I thought Id do a quick write up. They have been in and working for the last 4 years, so apologies if Its not complete.
Firstly you need the light units, complete with the lens and relector. These are both different to the standard light unit lens and reflector and have "D2R" engraved on the lens.
Then you need the ballast units, Original 202 ones were impossible to get hold of cheap, but after some help from mbenznl and mike-c200 and alot of research, found out that the Audi TT ones are the same, but have different connector plug, and the wire is shorter. Other than that exactly the same. Loads of these around on German Ebay.
Found the MB plug part number (will need to dig this out) and changed the plug over.
Next thing to sort out is the leveling. The OEM Xenons have an electronic auto levelling, I replaced this with the Vacuum leveling that mine already had.
For this you have to take the lens apart
and tug at the leveller to pull it out
then you will see the hole the leveller has to push into.
you cant push it in without taking the lens off as you need to hold the lens from the front whilst pushing the leveller on.
Next was to mount the ballast units, as the TT ones have shorter leads, you cannot mount them in the oem place which is under the bumper, so they were mounted in the engine bay, making sure they were safe from rain water.
heres a pic with 1 normal and 1 xenon
Best mod I ever did, driving with the xenons is another world!
mods might want to move this into the how to section?
