How to demist windscreem on W203?
Discussion in 'Electronics' started by stephenmercedes, Dec 3, 2018.
  1. stephenmercedes
    stephenmercedes Hardcore MB Enthusiast
    750
    Apr 15, 2018
    UK
    Car:
    W203 C240 (LPG conversion) RIP
    2001 C240,W203. This morning ambient temperature was 2c. The inside of my windscreen badly needed demisted, yet on pressing the arrowed button (which I believe is the demister?) it took a good 10 minutes of me sitting on my driveway waiting for enough screen to become visible to safely drive off! My 23 year old Toyota clears the windscreen in a minute, maybe two at most.
    What is the quickest way to clear the windscreen on a cold winter morning?
  2. alecmascot
    alecmascot Hardcore MB Enthusiast
    209
    Mar 16, 2016
    North East UK
    Car:
    C220 CDI 57 plate
    Is your thermostat working as it should ?
  3. MercedesDriver
    MercedesDriver Hardcore MB Enthusiast
    1,353
    Mar 19, 2013
    Near the forest
    Car:
    S212 E250 CDI
    I would suggest changing the cabin pollen filter and cleaning the filter housing, it always worked with my cars.
    Ted likes this.
  4. OP
    OP
    stephenmercedes
    750
    Apr 15, 2018
    UK
    Car:
    Yes, engine temperature has no issues
    Filter is brand new (well, a few weeks old) and housing vacuumed.
  5. PobodY
    PobodY Hardcore MB Enthusiast
    2,443
    Aug 23, 2016
    Stoke-on-Trent
    Car:
    CLK350 Sport, Nissan GTiR
    Air con on to dry the air you're demisting with?
  6. OP
    OP
    stephenmercedes
    750
    Apr 15, 2018
    UK
    Car:
    OK, can you confirm which button should be pressed to ensure this? (A/C is definitely working as I had new radiator, and recharge 4 months ago...)
  7. Ted
    Ted MB Club Veteran
    5,537
    Feb 26, 2004
    Bourton on Dunsmore
    Car:
    SLC 250D AMG Line, Yamaha XVS 1100, Jeep Renegade
    Pressing that button should enable aircon.
    The aircon needs to be working to demist the screen quickly.
    On my clk it took anywhere from 2-5 minutes to clear at this time of year depending on ambient temperatures and humidity.
    You may also have a leak into the interior leaving some dampness in there. There was a lot of rain at the weekend.
    Feeble likes this.
  8. GP801
    GP801 Hardcore MB Enthusiast
    2,850
    Jun 18, 2010
    Sussex and Tuscany
    Car:
    2003 W209 CLK, 2005 R171 SLK in UK, 1995 S124 E280 in Italy
    On some models (our SLK for instance) pressing the demist button gives full heat and power to the screen but turns the AC OFF! On the CLK which is similar to the 203 the AC stays on. We had an early 203 which had the same issues with demisting. Allegedly the recirculation function flaps were installed the wrong way round. Was told it was a known issue on some of the early cars.
  9. GP801
    2,850
    Jun 18, 2010
    Sussex and Tuscany
    Car:
    Also the AC won't work if the outside temperature is low. Not sure of the exact figure but 4C rings a bell
    Rory likes this.
  10. OP
    OP
    stephenmercedes
    750
    Apr 15, 2018
    UK
    Car:
    Odd that there are so many opinions on how exactly the ventilation system actually works in practice. The owners manual is very light on any such detail on what should be a very basic function. I guess Mercedes think the owner's chauffeur will sort it all out :D
  11. whitenemesis
    whitenemesis MB Club Veteran
    15,545
    May 7, 2007
    Car:
    Lexus RC300h F-Sport 2016
    A scrupulously clean interior windscreen also helps.
    That said my S203 '05 would take an age to demist, being diesel there was no heat to help but it was the same with the CLS, very slow and perversely it was always the passenger side that cleared first!!
  12. Stratman
    Stratman Hardcore MB Enthusiast
    4,464
    Jun 15, 2003
    Sunbury
    Car:
    W203 C200 CDI '04Estate
    Driver's side the the fatherland ;)
    whitenemesis likes this.
  13. John N
    John N Hardcore MB Enthusiast
    793
    Mar 22, 2017
    Peterborough.(Scot on Permanent Tour!)
    Car:
    E220D 4Matic P+
    Is this asking about the Front or Rear Screen? :confused:
  14. OP
    OP
    stephenmercedes
    750
    Apr 15, 2018
    UK
    Car:
    Front LOL You can always drive off with a misty rear screen, most commercial vehicles don't even have one! :D
  15. John N
    793
    Mar 22, 2017
    Car:
    E220D 4Matic P+
    The reason for asking was the fact that the Demist Switch you have highlighted looks like the Rear to me! The Front looks more like the same type, but the opposite side in your Picture! o_O
  16. GP801
    2,850
    Jun 18, 2010
    Sussex and Tuscany
    Car:
    The button highlighted is for the front
    Greenmanslk and stephenmercedes like this.
  17. Feeble
    Feeble Hardcore MB Enthusiast
    234
    Apr 19, 2013
    Gosport, Hampshire
    Car:
    C43 AMG
    I'd suggest there might be damp somewhere too. My car took ages to demist yesterday morning and it wasn't until I was halfway to work that I remembered I put a damp carpet in the boot that I used to keep myself off the ground when working on the car at the weekend. Doh. :wallbash:
  18. Rory
    Rory MB Club Veteran
    7,212
    Mar 12, 2005
    Cheshire, UK
    Car:
    C270CDi Estate (late 2004 facelift model)
    I'd go for this as the answer. It's to stop the evaporator freezing.
    It can be a bit of an issue if you leave the a/c on all the time. Start the engine on a cold morning with the evaporator wet from last use, the a/c doesn't work due to low temp, so the system dumps damp air into the car.
    stephenmercedes likes this.
  19. Greenmanslk
    Greenmanslk Hardcore MB Enthusiast
    774
    Apr 7, 2017
    Car:
    SLK (172)
    Post deleted
  20. moonloops
    moonloops MB Club Veteran
    5,157
    Oct 8, 2009
    :Location : Location
    Car:
    W204 C350 CDI AMG Sport
    Maybe stop pressing buttons and use a decent micro fibre cloth to wipe all the window insides ? :D
    Just don't leave the cloth in the car, dry it out at home.
Share This Page
