How to fit AMG accelerator pedal?
JC180
Manchester
2010 Mecedes Benz C250 CGI Sport Auto Estate
Hi all
I have just ordered the fancy SS and rubber stud pedals but I am a little confused how to fit the Accelerator pedal. The others just slip on but this one is more complicated and I don't want to break anything down there.
Anyone done this that could give me a few pointers?
Cheers
Jacob
The accelerator pedal I got was the whole thing (not just a cover). Remove the pin at the top (as above), let the pedal fall forward, remove the two plastic nuts. Reverse to fit the new pedal assembly.
Thanks Bobby Dazzler.
Bill thats what confused me as I got a complete assembly.
Where are the two plastic nuts located?
Cheers
Also a smear of washing up liquid on the brake and parking brake rubbers gets them to fit a lot easier.
on the floor, remove the carpets..
mats or carpets?
Cant see how there can be screws under the carpets. The only bit I'm unsure of is how to connect the base of the pedal (two holes?), I understand the cotter pin bit.
There is a plastic cap (I think) hiding the nut heads
I also recieved the whole assembly for the gas pedal and it was a lot lighter than the old one , not sure why
Remove the mats. There were 2 plastic bolts connecting the pedal to the floor, undo them and remove the cotter pin at the top of the pedal and refit the new ones
