CabrioChap
- Jan 16, 2017
- A238 E350d 4Matic CABRIOLET 2018
In case anyone has the desire to drill holes in the interior of their car, here is how to fit the mounts and trim rings for the Mercedes wind deflector.
Parts needed are:
A2388681000 TRIM RING x1
A2388680900 TRIM RING x1
A2058680200 MOUNT x1
A2058680100 MOUNT x1
Cost was approximately £23 + postage
The Trim rings come with the bolts already in place, so these don't need ordering separately. When I ordered the parts, A2388681000 was not available, so I ordered 2x A2388680900 instead.
This made it a bit tricker and the finish is not great. I am hoping that the other part will come back into stock in Germany so I can swap it over later.
I used this video for reference and it was spot on. Cabrio supply wind deflector fitting, getting the seat base out requires you to push it back, before pulling it up to 'unhook' it. No amount of just pulling at the thing will release it. It's probably not necessary to remove the base and back side pad, as everything just un-clips. but it gives you more room. I also had the roof partly raised for space.
Once everything is put back together, the wind deflector clips in place and the bag can be stored behind the seats in the space designed for it.
Parts needed are:
