- Nov 6, 2007
- Location
- North Oxfordshire
- His - Denim Blue A220 AMG Line Premium / Hers - Obsidian Black R172 SLK55
Yes, it does work with gpx files exported from BaseCamp, or saved from MapSource
Thanks for the reply, the download link doesn't seem to work anymore, perhaps because the post is a little old.Yes, it does work with gpx files exported from BaseCamp, or saved from MapSource![]()
Hello Malbry
Excuse me to disturbe you with that.
But If you could have a look on my problem.
After done several test and didn't find a solution, my last KML doesn't work in Mercedes comand GPX.
May be I use My Maps in the wrong way
Details
Used Routes107 version
Make my KML with the last version of Google My Maps
Your program works very weel (only in Single GPX File)
But the GPX isn't read in the Mercedes comand.
I look forward and compare a GPX who worked with the new one.
I saw some differences in the header of the file and test a copy of the header from the old gpx file to the new one =NOK.
I have attached a zip files (7zip) which contains :
The A file is the old one who is OK
The B is the KML of the new one
The C is the gpx transformed by Routes107 = NOK
Sorry for my poor English
Good Easter week end.
Hello Malbry
Details
Finaly I found an alternative solution :
I saved my KML in KMZ in Google My Maps
I import the KMZ in Basecamp (Garmin soft)
I export the basecamp data to GPX file
I use Route106 to transform the GPX file for Mercedes Comand = :bannana::bannana:
In attach the gpx from the route106.
Hope this help you to find why (my) KML to the Routes program doesn't work
Regards
Hi Jac,
I've replied by email. Your Basecamp gpx file had 35 via points which exceeded my program's internal limit of 30 via points. I've sent you a modified version with the limit increased to 50, which works when I run it against your file. Hope this helps.
Regards,
Malcolm
