Bellow
Hardcore MB Enthusiast
Yep a handy video - also show his method of retorquing the centre bolt. I'm hoping my holding tool can fit behind the pulley to access two of the 12 holes I opened out. I'll do it as per Haynes. I removed the cover with the sump still on and it didn't feel quite right. Now I've a better idea of what I'm doing, I can move faster than the RTV can set - and the weather can change as we are due a storm over the weekend so definitely want the sump back on before the wind gets up.
The two rubber O-rings I think may be for the casting that the oil filter fits onto and carries the oil cooler pipe. (It's a blast learning a new engine but it isn't half exhausting!)
The difference as far as I can tell between metal and plastic covers is the plastic one is roomier around the crank for the reluctor ring driving the CPS. You must be using distributors. The plastic cover is apparently usable on earlier motors - and comes with a blanking plug for when the CPS sensor isn't needed.
The engines you build - for AC Cobra replicas - yes? Anything else? And why not the Vortec?
