How To Protect You Car From Road Rage!
D
Deleted member 2227
Guest
Firstly the formalities.....
"HOW TO" Disclaimer. Please Read. Use Of This Section Assumes Acceptance!
You understand And Agree That Your Use Of This Section And Content Is Made Available And Provided To You At Your Own Risk. It Is Provided To You "as Is" And We Expressly Disclaim All Risk And Damage To Any Persons Or Vehicles As A Result Of Its Use. We Accept No Liability Whatsoever For The Content Or Its Use. Content Is Not Guaranteed Correct. Content Is Not Guaranteed To Be Authored By A Professional Or Otherwise Qualified Person. Modifying Your Vehicle May Invalidate Your Vehicle Warranty. Modifying Your Vehicle May Become Addictive.
Ok. First of all you need to replace the radiator with two smaller ones and make a frame that sits about 10inchs higher than the normal one.
The engine/gearbox mounts also need to make about 8inchs higher in order to make room for the Rockets.
The fuse boxes and ECU need rewired to the boot in order to make room for the machine guns ammunition!
Further details can be provided if neccessary however the finished mod should look like this.
PS. I would strongly recomend not cutting me up;)
Guns first!
.....not if you fit a cat!
...on second thoughts, the flame thrower wouldn't fail but the measuring equipment might get lightly roasted!
Les
